Previous in Forum: Wrong Metering CT Ratio   Next in Forum: Tension and Draw Control on Paper Machine
9 comments
Cable Size
10/13/2010 7:11 AM
how the cable size decided for diffrent current
Good Answers: 170
Re: Cable Size
10/13/2010 9:39 AM
By referring to Standards or to the Cable manufacturers' cable current rating tables.
Re: Cable Size
10/13/2010 10:54 AM
Please refer to your cable ampacity
Good Answers: 42
Re: Cable Size
10/13/2010 10:29 PM
Dear guest it depends on what is your level of decision making. If you are an engineer designing a large power distribution system it is highly technical matter and various technical parameters have to be considered before finalising your cable size . The subject was discussed in detail in various earlier threads in this forum.If you are an armature then refer cable manufacturer's technical recommendation for selection of cable.
Re: Cable Size
10/13/2010 11:44 PM
Sir,
Can u give me any chart which gives the selection of cables for different current loadings.
Re: Cable Size
10/14/2010 2:17 AM
→ British Standard 7671 again. <sigh>
Good Answers: 42
Re: Cable Size
10/14/2010 4:14 PM
All cable manufacturers provide this chart . You can get it from any local cable dealer . All electrical specification books and electrical engineers handbook and even some engineer's diary provide it . If you are a resident of India please get the copy of IS 3961 ( part II)1967 . This provide the current rating chat for AC 650/1100 volts aluminium cable
Re: Cable Size
10/15/2010 2:30 AM
Thanks....
Re: Cable Size
10/14/2010 4:03 AM
The continuous current rating of cables considerably depend on size and kind of their conductors, and the insulating materials. The conductors affect to efficiency of electron flowing, for AC, on conductor surface, and insulation structure effects to the operating temperature, temperature between conductor and insulation. The higher operating temperature is, the more amount of current you get.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
Re: Cable Size
10/14/2010 6:07 AM
use ETAP
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Anonymous Poster (2); electricalexpert65 (1); PWSlack (1); ranjeet (1); sms149 (1); T-lek (1); V.I.Abraham (2)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
