Previous in Forum: motor winding   Next in Forum: Electrical System Planning Software
Selection of Main Breaker for Starters
10/13/2010 1:25 PM
Hi Friends,
How can i calculate the rating of main breaker for motor starters, DOL starters and Star-Delta Starters?
Thanks,
Ammar
New Zealand - Member - Kiwi
Good Answers: 29
Re: Selection of Main Breaker for Starters
10/13/2010 4:10 PM
This is one of those questions that, if you have to ask it, you probably aren't qualified to do the work, and should hand it on to someone who is qualified.
paulusgnome
10/13/2010 6:06 PM
Consult your local electrical code/regulations. They will have something such as multiplying the full load current by a specified number, which may depend on the type of circuit breaker being used.
India - Member - New Member
Good Answers: 164
10/14/2010 12:29 AM
If you need Type 2 co-ordination as per IEC, the recommendation must come from the supplier of contactor+relay. Usually, reputed manufactureres also make MCCBs and publish co-ordination tables.
Register to Reply 3 comments
kvsridhar (1); Paulusgnome (1); Tornado (1)
