Hey guys,
I just joined this thread,pls i would like to know much about how to calculate load in a building that has been designed/autocaded.Is there a way of resolving on how to get the best way to balance the loads & calculate the current/KVa
Re: Load calculations in Autocad electrical drawing
10/16/2010 3:56 PM
AutoCad is a drafting and design program and while it is usefull for alot of things, it does not calculate or balance loads. You can use spreasheets to organize and list all the loads, but again AutoCad does not do the design for you.
There is one program that I know of that comes close to do all these calcualtions for you for commercial buildings. It will do basic lighting calculations and placement, calculate the loads and spit out a basic single line diagram complete with feedersizes and volteg drop calculations. But as with any software program, you must have a thorough understanding of electrical design to be able to rely on the product. As with anything, garabage in, garbage out.
If you are interested, you can visit their website.
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use. Galileo Galilei
Re: Load calculations in Auto cad electrical drawing
10/14/2010 5:16 AM
dear friend,
The question is not clear, the building that has been designed , means are you referring to architectural/ structural or electrical or entire part of building services.
Considering u r referring to work out total load requirement with 3 phase equally distribution network.
U need to work out lighting layout for various area of building separately with common area e.g, stairs, passage etc.
U need to work out variuos connected load other than lighting load e.g, computer network uit lets, ups, printers, xerox, and appliance at pentry/escalators, fire alarm system, sprinkeres, etc., water system, sound and music system if any , external capus/open area lighting , access contraol and so on.
On completion of above detail wotk out emenrgency back up power requirement if any.
Having tabulated over all work out SLD from point of receving of power till all point of power utilization/consumtion. Distribute 1 phase equipment load equally.
10/15/2010 10:59 AM
@nascon,I really appreciate ur contributions.but wat i really want is a system of computing d loads in order for them 2 be balanced on d 3phases.is there a method?it can be a residential building or whatever.
