Previous in Forum: Thermal to Electric Energy   Next in Forum: CAN ANY BODY TELL THIS?
PV Panel Moisture Issues
10/14/2010 8:54 AM
How do PV Panels deal with the moisture issue? I have been on several sites and they do not even address it. Seems to me that if the panel gets hot as it will, it will create internal pressure in a sealed panel; in which case it has to deal with the pressure. If it is not a sealed unit, the pressure will escape to the outside and when the panel cools down it will 'suck' in outside air containing moisture. Is this just not a issue with solar cells? Seems to me that it is.
The time has come the Walrus said to speak of many things, of shoes and ships and sealing wax, of cabbages and kings.
Pathfinder Tags: PV panels solar cells
Re: PV Panel Moisture Issues
10/15/2010 3:28 AM
Moisture inside a working panel is its worst enemy. Hence, all panels are designed to keep moisture out. Moisture will not only "fog" the inside surface of the panel obstructing light, decreasing efficiency, it also slowly causes corrosion to electrical contacts. This corrosion increases resistance at the solar cell and reduces current flow. This resistance also causes heating which further reduces the solar cells efficiency. This has a knock-on effect that nearby cells also are affected by the heating and current flow. If the panel has a highly rated power output and resistance is great enough, there is a real potential for shorting and serious damage to the panel, which is another reason water and electricity don't mix.
All we want are the facts, ma’am.” Sgt Joe Friday, "Dragnet"
10/15/2010 3:59 AM
Never have torn one apart but it seems like a commercial panel must be a solid piece with no air space in the cell assembly?
Good Answers: 32
10/15/2010 10:04 AM
For solar cells, front surface is hard deposited on glass and the then covered by a protective layer from behind. Moisture can enter back or side ways if panel is not moisture shielded properly. Light sensitive layer can not be easily affected by moisture, but back layer can be as sealant quality matters a lot there. Damage is rather show and perhaps solar cells are built for 20+ year life span..
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
10/16/2010 4:52 AM
In control panels to deal with moisture we have an arrangement with Anti-condensation Heater(ACH).More over we have silica crystal to absorb moisture.Cover the crystal in a porous cloth and put it in the panel.When it absorb water the color change from blue to red.To reuse it dry it in sunlight or fry it dry.
10/16/2010 4:57 AM
ACH
hithuanand (2); russ123 (1); sbruel (1); Shyam (1)
