Previous in Forum: How we Can Increase the Strength of Material   Next in Forum: Calcium hypochlorite weight.
R 744 CO2 Refrigerant
10/14/2010 6:30 PM
I have a strong interest in this refrigerant but am getting a lot of variation as to the normal working pressures. In PSI it ranges from 900 to 3500. Boiling point is -78F from the information. Can someone enlighten me in the working pressures presently in use and the best type of compressors. Also any pro and con to this refrigerant as it applies to commercial use. All info welcome and thanks in advance.
Re: R 744 CO2 Refrigerant
10/14/2010 8:20 PM
I don't know what info would best suit your situation, but here is a link with basic pressure-temperature and pressure-enthalpy charts:
http://www.achrnews.com/Articles/Feature_Article/97d657d6f5d5a010VgnVCM100000f932a8c0____
10/14/2010 8:35 PM
I do thank you I have found out a great deal of quality information. Love this site.
10/15/2010 9:21 AM
Since this is CO2, and being that the pressures that Roy referred to could put it into the supercritical range (over 1085 psia and 31ºC), I'm thinking that there would be some serious deviation from typical refrigeration systems?
10/15/2010 8:36 AM
M&M Refrigeration, who I think is in Baltimore, has supplied the machinery for several cold storage plants with two stage, ammonia/CO2 systems. As I recall, after you get down to about -4 F CO2 works pretty good on the low stage.
There are others, but I don't have their names right now.
I have heard said the EU has decreed CO2 be used for automotive AC, but found no proof of it. I wonder how you can get 50-55 degree air out of something so cold as the temperatures CO2 would probably have to run at.
CO2 might become a great refrigerant, but operates some terrific pressures.
It is sad ammonia has gotten such a bad rap - another victim of the the media, the trial lawyers, and the government bureaucracy.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
10/16/2010 1:48 AM
CO2 has no ozone depletion potential and insignificant global warming potential. Other principal benefits of CO2 are that it is a natural substance, it is cheap, readily available, not poisonous in any common concentration, and nonflammable. Carbon dioxide (CO2) is considered to be an alternative to HFC refrigerants due to its nonflammability,non-toxicity and small global warming potential. In UK some supermarkets have already switched over to the CO2 systems. It is emerging as one of the potential natural refrigerants. Sulphur dioxide (SO2), Carbon dioxide (CO2) are other natural refrigerants which are in use since many years. But their applications are mostly in marine engineering. To commercialize these natural refrigerants several researchers are working but still there is a long way to go on this issue.
Coldspot (1); Mikerho (1); mrswamy (1); roy hammy (1); Tornado (1)
