Previous in Forum: Centrifugal Pump Selection   Next in Forum: Plate Thickness For Blind Flange
Water Jet Diverter
10/14/2010 10:01 PM
anyone know any product that can divert high pressure water?
i have an existing water jet cutting system with water pressure to ~400-500bar
I would like to add on a diverter into this system to divert water away without shutting off the water jet pump.
Re: water jet diverter
10/14/2010 10:15 PM
Divert water away, where? Doesn't make sense to me.
Ruby lined valves.
10/14/2010 11:35 PM
the water goes out to 5 nozzles to do water jet cutting...
i would like to divert water from 3 nozzles while 2 others remain the same
due to the high pressure i cannot close off the 3 nozzles. this will cause a pressure surge and damage the system.
Good Answers: 19
10/16/2010 1:00 AM
Why not ask the manufacturer. If this was possible they may be g=having a different model/attachment?
10/17/2010 12:01 AM
i have asked the manufacturer so far no feedback.....im actually sourcing for others water jet pump supplier for this add on....
Good Answers: 181
10/15/2010 5:59 AM
The plant I used to work on used Aqua HP pumps. We had divert and flow control valves from Aqua
http://www.aquaenergy.com/index.htm
ducon (1); lyn (1); tofumaster (2); TonyS (1)
