Previous in Forum: Water Jet Diverter   Next in Forum: Wafer Check Valve
Plate Thickness For Blind Flange
10/15/2010 1:31 AM
How i will select plate thickness for blind flange fab. Accordind test pressure?
Re: PLATE THICKNESS FOR BLIND
10/15/2010 2:33 AM
if you have enough strenth to do the expriment,it will be better .usually,we design it by experience.
10/15/2010 5:41 AM
Consult ASME B16.5, select the Blind Flange according to your required pressure, hope it will help you
Re: Plate Thickness For Blind Flange
10/24/2010 6:13 AM
Use the formulae below,
tp=ID* SQRT(kc*P/Ss/E) + A
Plate thickness tp
Thickness of pipe tsr
Nominal DIA OF PIPE NP
Factor of thickness of plate kc kc=0.33(tsr/t) min shall be 0.2
Inside diameter (mm) ID
Internal design pressure P Mpa
Maximum allowable stress Ss Mpa
Joint efficiency E 0.85
Additional length or allowance A 3
Anonymous Poster (1); JCS (1); piping_engineer (1)
