Previous in Forum: Electrical Drawings   Next in Forum: 12Vdc Motor/Generator
Frequency - Increase-Decrease
10/15/2010 3:43 AM
What happen when 10 hp 1440 rpm 3phase 50 Hz rated motor use with40hz power other mean what effect on induction moter,s speed,amp.&load capacity from increase-decrese of frequency
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
Re: frequency
10/15/2010 4:17 AM
Frequency has direct impact on RPM - N = 120f/p where f is frequency and p number of poles n here 1500 sync speed means 4 pole hence change due lower frequency shall have sync speed as 1200 RMP
Accordingly speed - torque curve will change
nascon
Re: frequency
10/19/2010 5:06 AM
<...Accordingly speed - torque curve will change...>
It would be better to state that the motor will be operating on a different characterisic curve because of the changed frequency.
Register to Reply 2 comments
