Previous in Forum: PanelView 600 Screen Flipped   Next in Forum: 6600 Motor on 3300 Volt Supply
Why We Used Relay Curve,SI,VI,EI For Relay Setting?
10/15/2010 10:16 PM
IN MY PLANT FOLLOWING CURVE ARE USED IN RELAY SETTING SIMPLE INVERSE, VERY INVERSE ,E I CVRVE ARE USED, PLEASE GIVE DETAIL. MY PLANT POWER DISTRUBUTION 33KV,6.6 KV,415 KV.
Re: Why We Used Relay Curve,SI,VI,EI For Relay Setting?
10/15/2010 10:37 PM
The first trick is turning off the Caps Lock, or stop holding down 'shift'. Whichever you're doing.
The first law of thermodynamics is you do NOT talk about thermodynamics.
10/16/2010 3:14 AM
A simple explanation is to create backup function to instantaneous relays, without compromising on system stability by avoiding delayed tripping.
Knowledge sharing is a WIN-WIN situation
Good Answers: 131
10/18/2010 9:16 AM
The different time characteristic curves are used to allow relays to be coordinated with each other, with other protective devices (fuses for example), and with equipment to be protected (transformer thermal damage curves, motor damage curves, etc.). The characteristics are chosen to give the most flexibility and selectivity between relays, so that (hopefully) the one nearest the fault will trip first, before a more distant relay takes out more of your facility's electrical system.
Good Answers: 170
10/18/2010 9:17 AM
If you are an industry with short cable lengths, please go for Simple Inverse Curve only. Very Inverse is used for long cable lengths and Extremely Inverse for loads with high peak currents.
Register to Reply 4 comments
electricalexpert65 (1); Mizuti (1); mountk2 (1); PeterT (1)
