Previous in Forum: WiFi Utility Needed   Next in Forum: Disabling Charging on IPT UPS
8 comments
Sensors
10/17/2010 11:40 AM
hi...i am an electronics engg student.I want to know that what kind of sensor csn be used in railway track to detect the train ? it should be robust and economical. presently i am using IR sensor but it has many limitation in real time application. please help me....
Re: sensors
10/17/2010 11:55 AM
No help here.
You need to do your own homework. There was no internet when most of us were learning, so we had to read books and do research, on our own.
If you were to make some selections based on the information before you, then come here and tell us why you chose the sensor you did, we might help. But I'll not do the work for you.
Re: sensors
10/20/2010 3:16 PM
I do made a research about suitability of sensor and i came across the following options:-
1>IR sensor , that i am presently using in my project "Automatic Railway Gate Crossing".
Other options are: Electromagnetic relay based detection...../ By using Pressure Transducer.../ or by using RFID technology........
so ......which one of the above will be most suitable.........
Re: sensors
10/20/2010 3:36 PM
Have you considered a SPST momentary switch with a paddle, mounted alongside the track so the the wheel "lip" will trip it. Then a timer to raise the gates after last car goes by?
Report back on that.
Re: Sensors
10/18/2010 7:14 PM
Just a good ol boy with a little thought... The way I understand it the crossing lights use a current between the rails. since the are "parallel" the only way to connect them is when a train comes by. with the welded rails you may want to use some sort of signal strength arrangement. ask a RR guy. Just go stand on a track and LOOK at them and THINK about it. hell they probably all have transponders on them now, use that. Just think about it and don't rely on someone else to get the basic ideas from.
just a little ol hi skool drop out
simple elegant solutions. thank you okum, ockum, ahkum, you know the guy with the razor.
Good Answers: 60
Re: Sensors
10/18/2010 8:10 PM
Good Answers: 176
Re: Sensors
10/19/2010 10:27 PM
Banner Engineering makes vehicle sensors that can be buried
http://www.bannerengineering.com/en-US/products/8/Sensors/44/Vehicle-Detection
Re: Sensors
10/20/2010 10:28 AM
Register to Reply 8 comments
Anonymous Poster (1); Iris (1); lyn (2); madhumangal (1); peterg7lyq (2); PWSlack (1)
You might be interested in: Cable Glands, Flame Detectors, Infrared Windows
