Previous in Forum: Possible for Motors of Same kW to Have Different HP?   Next in Forum: Solution for Busduct Noise?
12 comments
Parallel Operation of Pumps
10/21/2010 5:20 AM
We've two submersible 3 stage condensate pumps installed at condenser of condensing steam turbine. Condenser has vacuum of 550mmHg. One of the pump is turbine driven and other is motor driven. One of them is in service and other as a stand by.
Since last two weeks we are facing the problem that both are not working independently. 1- When Turbine pump is taken in service after 3~4 mins its pressure and flow starts decreasing and RPM starts increasing, moreover the level in condenser starts increasing 2- When Motor driven pump is taken in service similarly after 3~4 mins its pressure and flow starts decreasing along with decrease in amp similarly increase of condensate level in condenser. Now both the pumps are running in parallel operation to keep the level of condenser normal. We've shut down at our plant and we've checked the condition of motor driven pump by pulling it out. It was found OK no wear of impellers etc. All gaskets of flanges were replaced, but after start-up no improvement was observed. Water dam were created at mechanical seal locations and around base plate in order to avoid any problem of vacuum breaking, but problem still persist. Moreover, the steam condensate is very clean medium so no chance of blockage of lines.
What may have gone wrong? What improvements we can make to the system to make it work?
Re: Parallel operation of pumps
10/21/2010 6:55 AM
Were any changes made to any other part of the system 2 weeks ago? Even if it seems unrelated.
Do you have a separate feed pump going to boiler? If so, this could be faulty,causing back pressure to condensate pumps.
From the sounds of it, the problem lies somewhere between your condensate pumps and the boiler.
This sounds obvious, but have you checked to make sure all valves upstream of pumps are fully open?
10/21/2010 8:12 AM
We've to shut down the turbine and condenser vacuum breaks but we've checked the values of vacuum they are same as previous.
No seprate pump for boiler
You are talking about the problem at discharge of pump please elaborate as according to us the drop in amperes, flow and pressure are result of suction problem between pump and condenser.
Yes all valves at upstream of pumps are fully opened
10/21/2010 9:03 AM
Sorry, I misread, you said pressure decreasing.
With pressure decreasing and rpm increasing and impellers and pump checking out ok, the only thing I can think of is air getting to the pumps somehow, but I can't imagine how. Hopefully, someone can offer some insight.
Do these pumps have strainers? Possible sediment buildup.
You said the water is clean. Eliminating the possibility of a clog, but you need to visually inspect strainers to truly eliminate that option.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
10/21/2010 10:19 AM
Kramarat is asking the most important question. I have about 15 years of power plant experience and I will say that when problems arise the #1 question to ask is "What has been done recently?" (maintenance, valve line-ups, operations, etc).... It's important to fully explore this because nearly every time it points to the answer.
Most of what you are describing sounds like the normal operation for a pump being throttled. That is, if a pump is pumping at some point on the curve and we throttle down the discharge, the pump will pump less (and the condenser level will rise), the lower flow means less energy (amps go down). The only thing that doesn't fit this scenario is the pressure is decreasing.
What is happening to the boiler level?
From the description of symptoms it sounds almost like normal operation to me. Boiler level might start a little low, system calls for water, pumps pump, boiler level nears setpoint, system calls for less water, control valve throttles more, flow/amps go down, condenser backs up. Is it possibly just a water management issue? Without more details its hard to say...
The only other thing is that being common to BOTH pumps it is unlikely a problem with either pump, it's something common between them such as a closed suction valve, etc.
Go back to Kramarat's question... What happened 2 weeks ago??
Sometimes my thoughts are in a degree of order so high even I don't get it...
10/22/2010 6:50 AM
I've got my money on clogged inlet filters/strainers. For both pumps to be affected simultaneously, to me it's the most plausible explanation. It's possible, but I think pretty remote that both pumps would be working fine 2 weeks ago, and wear out at the exact same time.
To the OP, here is a good list of contaminants and ways to treat. Look through entire site, lots of good info. Please get back to us and let us know what you find.
http://www.lenntech.com/applications/process/boiler/boiler-feed-water.htm
10/22/2010 1:22 PM
GA
I would add for clarity:
1- If the condensate temperature is different from before, or has increased from what it used to be, it might become near to the evaporation point at the pump. This could be due to the cooling circuit of the condenser (Which makes the vacuum...) having a problem (?). Then Cavitation will occur. This can explain the lower flow volume, lower pressure and the speed increase of the turbine (Steam control compensating...).
The electric motor speed will change marginally due to less power demand but remains within the nameplate value (Asynchronous) or if Synchronous motor, does not change.
Therefore: either cloging or cavitation but still at suction. Check .
Re: Parallel Operation of Pumps
10/21/2010 9:10 AM
Not knowing what your elevation is I assume that your vacuum is low. Any idea why?
I know it is kind of basic, but are your recirculating valves wide open?
If you fail to follow through, you will fail.
10/21/2010 10:21 AM
It sounds as though the pumps are working so hard as to make the condensate boil at the pumps' inlets. If so, don't do it for too long as the cavitation caused by it will damage the impellers longer-term.
Try modulating the pump speed on the basis of the level in the condenser catch pot; presumably there is an instrument, otherwise no-one would notice the level going up.
Good Answers: 19
10/21/2010 5:22 PM
How old are the pumps? and when did you last check impellers for cavitation?
Good Answers: 117
10/22/2010 1:32 AM
Hi
Reading what you've said about the actions of both pumps when running is the way a submersible pump act if
either the inflow has a problem
the pump has a problem namely the impellers AND diffusers are worn.
I know you've said you have checked the pumps, have you put them on a test bench and compared the test results to the pump curve?
If you have NEW spare pumps, change out the existing ones to see if that makes a difference.
Not knowing how old, the duty time and the history of the pumps it could be just old age. Do you have a amp chart for the motor driven pump that might indicate a gradual drop in running current? Over time as the impellers wear, the running current drops as the efficiency drops even if you have super clean water, also the impeller is affected if its NOT running in its operating range, something else to check. Do you record the discharge pressure of each pump, if so look back at the charts
While I think about it have you checked the RPM of the motor? A drop in the motor RPM will change the pump curve, reducing the pump flow rate.
As you have only checked the motor driven pump check the supply frequency and voltage. For the Turbine pump, I cannot explain how the increase in RPM reduces the flow rate or why the RPM increases, it must be a large increase in RPM for you to mention it. How much does it increase by, what should the RPM be?
If new pumps don't solve your problem, then you don't have a pump problem and you need to look at something else and maybe take up the suggestions given to you in this forum
As for improvements, lets see what your further investigation finds first and how you make out with the good answers you've received so far.
10/22/2010 1:29 PM
If the hotwell or condenser was opened up for any work to be done, there is always the possibility that some construction material may have been overlooked when the doors were closed back up on the system. My first check would be to drain the hotwell and look for any obstruction between the hotwell and the suction side of the pumps.
Also, if the water level in the hotwell is allowed to get low, a vortex can develop at the suction of the condensate pumps. Normally, raising the level of the hotwell should reduce the vortex but not always. Perhaps you can temporarily shut off your motor driven pump to allow water to fill in the void caused by the vortex.
When you first start up to fill your deaerator, overfill the hotwell and closely monitor the hotwell level until you get the deaerator level and boiler level to normal levels.
Ron
10/24/2010 11:23 PM
Dear all!
Thanks for replying.
We've resolved the problem, there is a demin water valve at suction line for start up, we've tightened its glands and RTV sealent was applied at its bonnet. Now the problem has been resolved.
Register to Reply 12 comments
brich (1); ChaoticIntellect (1); ducon (1); kramarat (3); LAA_Lucke (1); otha (1); PWSlack (1); RG2 (1); UsmanS (2)
You might be interested in: Condensate Polishing Equipment, Condensate Pumps
