Previous in Forum: Socket Weld Reducing Tee or Reducer Availability   Next in Forum: Air Bleeds for PE Pipe
It's Getting Colder - Estimating Rate of Heat Transfer Across Boundaries
10/22/2010 2:17 AM
What is the simple rule of thumb calculation for estimating the rate of heat transfer across boundaries? i.e. If I have minus 50 deg C Thermal oil on one side of a thin plate one metre square and 40O litre of fliud at 20 deg C on the other side pumped at 20 litres per minute. How long will it take to cold the liquid to minus 20 deg C?
Re: It's getting colder
10/22/2010 2:26 AM
It depends a lot on how much oil (especially how thick) is on the other side. No simple single rule is likely to suffice, because it also depends on the thermal conductivity and turbulence of each fluid. In the "simple" formula Q = KA(lmtd), there is lots of devil-detail in K, the thermal conductivity factor.
10/22/2010 4:26 AM
It depends upon the cooling capacity of the thing that is generating thermal oil at -50degC. If it can't keep up then it will take forever.
Is the 20l/m being recirculated or is it going somewhere else?
Re: It's Getting Colder - Estimating Rate of Heat Transfer Across Boundaries
10/22/2010 8:35 AM
If you don't know the thermal conductivity of either of the fluids or the separator plate what good will formulae do you?
Besides this sounds like homework.
10/23/2010 12:11 AM
I convection mode of heat transfer heat is carried away from the wall surface by the flowing fluid. Convective heat transfer can be either forced type or free or natural type. Heat transfer coefficient is very important to arrive the heat transfer rate.Q = hA TD. H is the heat transfer coefficient and T.D is the temp difference. If h value is not available we cannot complete the calculation
Register to Reply 4 comments
lyn (1); mrswamy (1); PWSlack (1); Tornado (1)
