Previous in Forum: Business Intelligence - Dairy Manufacturing Unit   Next in Forum: Tascam 2488 Recording Studio
10 comments
Write Protected Error
10/22/2010 6:13 PM
How will i get my flash drive back to normal,
I have a 2G flash drive which i used it for only 4months and when i want to open it -i cant but only this text that pop out on its own window ( windows- 'Write protected error' and down below it reads " The disk cannot be written to because it is write protected. Please remove the write protection from the volume in drive \Device\Harddisk1\DR2"
i used so many anti-virus programs and comand prompt to delete virus incase the flash is infected but the problem never solve.
Re: Write Protected Error
10/22/2010 6:34 PM
Is it still under warranty? Do you even know the warranty details? If it is, contact the manufacturer. If not, throw it away and buy a new one.
If it were me, I wouldn't even waste my time trying to fix it. A couple of hours of my time is worth a helluva lot more than a 2GB flash drive (at today's prices).
10/22/2010 7:12 PM
Look closely to see if there tiny slide switch on it to turn write protection on/off. Also click and right-click any menus associated with it to see if there is a check box or the like for toggling write protection. This is not likely to be a virus--more likely the accidental usage of the feature.
10/24/2010 1:00 AM
Yes, this could be the cause, most likely.
10/23/2010 5:32 AM
Good Answers: 140
10/23/2010 11:17 AM
Can you read from the stick? Try it on another machine. The error msg does not sound right. I am surprised to have the OS report it as "HardDisk1", it should be refereed to by the OS according to the name of the USB port/drive name.
10/24/2010 1:47 AM
I have a lot of experience with this one. Do yourself a favor and don't waste time. I make nothing off of this reccomendation, but I know this product absolutely WORKS! Go to http://www.easeus.com/. You will find what your are looking for. I have retreived data from devices that I had lost all hope for.
10/24/2010 9:16 PM
Thank you all so much.
10/25/2010 7:07 AM
You say it's a 2 Gig solid state hard drive.
Do you mean it's an SD card or some other physical format memory stick.
USB stick perhaps? What make/model?
10/25/2010 7:04 AM
If it is the sort with the separate data card, with a mechanical switch down one side, for the write protect, the switch can cause problems, usually solved by not pushing the card all the way in. Not the usb into the pc, the card into the usb holder.
jim
10/26/2010 12:31 PM
There's gotta be some manual turn on/off in the device. I believe that happenned to me before .
Anonymous Poster (1); cnc jim (1); davidforbes (1); Mikerho (1); North of 60 (1); Randall (1); rodney schulze kava (1); Tornado (1); woodygb (1); yesyen (1)
