Previous in Forum: Looking for 1.27mm Single Row Connector   Next in Forum: Data Transmission Through Telephone Line
ISP Programing on AT89S51.
10/23/2010 1:25 AM
I am a new to MCU and want to program(ISP) my AT89S51 IC using simple Parallel cable connected with my MCU on Pins (p1.5,p1.6,p1.7 and and Reset). I can read the Data from my MCU but unable to write data (Program) to MCU. When I try to read data software shows an error ("Unable to write at 00000H, 174 byte write" or something like this). I have tried different software but same error occurs. Please guide me the correct methode
Re: ISP Programing on AT89S51.
10/23/2010 9:40 AM
Acronyms should be defined on their first use. What is an MCU.
You should refrain from their use PDQ or ASAP!
10/24/2010 2:19 AM
" Is it plugged in ? " ... " Are you SURE it's plugged in ? " ... " Is it plugged into an outlet that is on a switch ? "
