Greetings,
I have a PC board video camera that I need to build a custom cable for. The camera came with a cable, but it is inappropriate for my use and I don't want to cut it up in order to build a new cable from the parts. The camera is built in Taiwan and the US Distributor knows nothing about the connector.
The connector on the PCB that I need to mate with is a shrouded header, single-row, 4-pin, with a .050" / 1.27mm pitch. The contacts are rectangular, approximately .01" x .02". I have attached a photo that shows the PCB and the cable connectors. The connector I need is compatible with the cable connector on the left side of the photo.
I have searched the major component catalogs and googled the specifications above, but have not found anything close. I appreciate your assistance and suggestions.
Thanks,
Les
