Previous in Forum: Resistors in Parallel   Next in Forum: Short Circuit Current
Requirement of Generator Circuit Breaker
10/23/2010 7:26 AM
What is the requirement of generator circuit breaker in power plant? Can't generator be tripped directly by switchyard bay breaker? In my previous company there was not GCB, generator was directly connected to grid with GT + switchyard breaker. While, in my present company, there is a Generator + GCB + GT + switchyard breaker scheme.
What is the criteria that GCB should be there in design or not?
Re: Requirement of Generator circuit breaker
10/23/2010 7:41 AM
caution/protection/maintenance/isolation/designing.
Good Answers: 170
Re: Requirement of Generator Circuit Breaker
10/24/2010 7:38 AM
Even though it is called a "Circuit Breaker", it can only be used as a switch-cum-isolator as it does not have any short-circuit making and/or short circuit breaking capacity. It is more used as an isolator.
10/24/2010 2:51 PM
Where the generator is connected to GT with circuit breaker in between, auxiliary power for power station can be drawn from the grid through GT (back charging) while keeping the generator isolated during any shut down.
10/24/2010 11:39 PM
IT DEPENDS ON THE USAGE AND APPLICATION.
FOR LARGE UMPPS THERE IS NO GCB.
IF THERE IS A GCB FOR SMALLER GT BASED PLANTS UPTO 200MW SINGLE UNIT THE AUXILLARY TRANSFORMER CAN BE SAVED .
BASICALLY IT OFFERS A LOT OF ADVANTAGES AND FLEXIBILITY IN CASE YOU HAVE A GCB.
AS FOR EXAMPLE IN INDIA TATA MUNDRA 5X800MW UNITS ALSO GCB IS USED.
S BHATTACHARYA
07/20/2011 1:10 AM
dear sir,
my name is deen iam working in thermal power palnt as a AE.,, i need GCB operation and scheme.,, can u //.
if u can.,, forward to <email removed>
thanking you
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Anonymous Poster (1); bsekhar (1); electricalexpert65 (1); pcchatur (1); rajakumar1985 (1)
