OK, so I have this nice Oriel arc lamp power supply and its corresponding igniter box. But before I blow something up and create a really nice expensive fire, can someone confirm that the way I think I should use this equipment is correct? Yes, I know I shouldn't be playing with things I don't understand, but there's a first time for everything.
As shown in the diagram, the igniter connects to the power supply through a Plus wire, Negative wire, and a three-pin Control Connection. The igniter is connected to the arc lamp as shown. When I hit the Igniter Button, the igniter should deliver high voltage to the lamp to get it started. And when the power supply senses a current, it turns off the igniter and keeps the arc going. Is this correct? Furthermore, is the connection through the igniter the actual connection through which the arc lamp is going to continue to get its operating current?
Help!
