Previous in Forum: Arc Lamp Question   Next in Forum: speed sensor output
Memory of vfd erases
03/17/2007 2:49 AM
Hai,
I am kathir vel working in ford india pvt ltd, chennai,India. Recently i had a problem in siemens mm440 vfd that the program memory was erased when 0v is connected to digital input terminal (for PNP DI configuration) and default seettings are stored. Also the unconnected DI's configuration is activated (ie. reverse command in DI 2) inspite of run command (configured for DI 1) is in ON state.
This fault was not able identify immediately. After long trials of different configuration & connections i was able to come to this conclusion, ofcourse 99% only.
So please clarify my doubt & the remaining 1%.
Thanks,
kathir...
Good Answers: 54
Re: Memory of vfd erases ????????
03/17/2007 5:42 AM
Hmm, let's see.
First off, I'd say that you should contact your supplier and ask for help. Or you could contact Siemens to ask for advice. For the meantime, this is what I can offer.
Are you saying that when you connect 0V to any digital input, the unit's memory is erased and reverts to default settings? Or is it just one particular input?
I'm not familiar with the Siemens MM440 so I don't know if you can configure a digital input to erase the program memory. 'Seems like a foolish thing to have .
Where is the source of your 0V? Is this referenced to the VFD COM? If not, you're supposed to use the VFD's own control supply (not the AC supply, the controls) for your signals. They usually have their own +24V and 0V or COM terminals for this.
If you're using a 0V signal from somewhere else, this could cause the problem you're experiencing.
Your other concern about the reversing seems unusual for a VFD. If the drive is running in forward mode, it's not supposed to immediately change to reverse mode. If I am wrong in interpreting your statement, please say so. Explain a little further.
03/18/2007 6:30 AM
We use many siemens vfd's in our plant and have never had this problem with ours. I would suggest that you replace the programmer unit if possible. You should contact the siemens hot line with your problem and explain the problems to them. They may have experience with that problem.
Mike Love
