There is a
proximity sensor 24VDC, PNP, NO, range 10mm at my machine for stopping a pusher
device. I want to install another Prox sensor with same spec in parallel with
old so that if anyone of both operate, the pusher stop device stop. But problem
is that for example if PS 1 is operated (out put high) and PS 2 is not (out put
low) the +24V from PS 1 can damage the PS 2 output side? Because if both
operate simultaneously the no problem but if one is operated and one not then a
question mark.
