Previous in Forum: Motor Winding Resistance and Phase to Phase Difference   Next in Forum: Paralleling Different Capacity Transformers
11/01/2010 10:25 PM
I test the motor winding resistance, the result of L1-L2 is 0.79 ohms, L2-L3 is 0.73ohms, L3-L1 is 0.68 ohms. My question is, does the winding resistance of the motor passed or failed? . .if failed, what is the reason?. .
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Motor Winding Resistance
11/01/2010 10:36 PM
The short circuit current depends on winding resistance.It may be the reason,just a guess.
11/02/2010 1:08 AM
Dear Sir,
Are the values measured before or after any failure ? This will help to get more reasons.
Manroop.Chennai.
Good Answers: 131
11/02/2010 11:03 AM
Please provide more info: Motor size (HP or kW), voltage, new or used, rewound, sitting idle for long time or just removed from service, hot or cold, etc.
How did you test the resistance? If you just used a digital multimeter, you probably will not get accurate measurements because it cannot push enough current through any oxidation, etc., on the contact points. You should use a low-resistance ohmmeter (such as the Megger DLRO series), or alternatively you can use a DC power supply that can output 3-5 amps, measure the voltage drop with the DMM, and calculate R = V/I. Readings should be within about 1% of each other.
As for reason for failure, could be any of a number of things: turn-to-turn short, poor termination, damaged winding conductor... That can only be determined for sure by tearing it apart.
11/03/2010 11:44 AM
What was it when new?
What does the motor manufacturer say?
Register to Reply 4 comments
hithuanand (1); manroop (1); PeterT (1); PWSlack (1)
