Previous in Forum: Motor Winding Resistance   Next in Forum: 24 VDC PWM Causes Objectionable Motor Noises in Housing
Paralleling Different Capacity Transformers
11/02/2010 12:28 AM
Two Transformers ,one is 1000 kva and other 500 kva, when fulfiling all other precautions for parallel operation(% impedence,voltage level,turn ratio ,etc) can be run in parallel ?
If yes,how they share the load ? if there is a load equal to the sum of total capacity of both transformers.
your,s
MZ
Good Answers: 181
Re: paralleling different capacity transformers
11/02/2010 1:18 AM
Is paralleling the transformers to be permanent or just temporary during a switching operation?
11/02/2010 1:20 AM
Dear Sir,
Any book in Electrical Engg will give you the General Conditions required for
the parallel operation of Transformers.
(1) Same Vector Group (2) Same turn ratio (3) % impedence with in 5 % variation
to limit circulating current among the Trs. (4) Protection Circuits to protect
Lessor capacity transformer from getting overloaded. (5) Preferable to have
equal capacity of Trs- or in the ratio 1:0.75 to be on safer side.
Manroop.Chennai
Register to Reply 2 comments
You might be interested in: KVA Meters, Transformers, Electronic Transformers
