Typically I use three phase 220 VAC motors and a solid state phase inverter to convert the single phase 220 to three phase and to regulate shaft speed. The useful speed is usually between 5 and 25 rpm, depending on the activity.
The application is for an optical bench where precision mirrors are being ground, polished and figured
Recently I built a new "portable" polishing table using a 24 DC volt motor and 20 -1 combined gear box. The unit is new and designed for a golf cart. Power is supplied by an accurate, regulated power supply or, when needed, a pair of 12v dc car batteries in series.
Speed for the DC system is controlled by a solid state PWM.
The problem is that the PWM output causes the motor to vibrate. When the frequency of the power pulses matches the natural frequency of the enclosure, the noise intensifies considerably to the point of distraction.
I built a new enclosure with the idea of lowering the natural frequency as well as damping the panels from being sounding boards. I also secured the motor firmly and added rubber isolation biscuits.
It's proving be more of a problem isolating the motor than I thought and I've come to wonder if perhaps instead of addressing the symptoms I'd be better off addressing the cause.
I've assumed that the PWM power curve is in the form of a square wave and that the noise is from the abrupt amplitude change in the square way profile.
Might something with a 'Soft switch" eliminate the problem? Is there a different type of DC speed regulator than can accurately control the speed of a 24 volt motor that draws about 7 amps and which doesn't sound like the Mills Brothers?
Thanks
L.J.
