Previous in Forum: 24 VDC PWM Causes Objectionable Motor Noises in Housing   Next in Forum: Earth Fault Problem - Main Feeder Tripping on Earth Fault
Good Answers: 181
Auto-synchronous Motors
11/02/2010 1:02 AM
I've worked on some weird and wonderful motors in the past but not on auto-synchronous motors. The nearest thing I've got to them were rotary converters but they were started by pony motors. (Just the merest rumour that the duty converters had to be swapped over would clear the electrical department, no one wanted to do it! It was like an electrical firework display with you stood in the middle of it).
This is something that puzzles me. An auto-synchronous motor starts as a slip ring induction motor. As the motor approaches full speed are the slip rings shorted or is DC applied to the rings at this point? If it is surely this must give one hell of a kick on the line current as it drags it's self in to synchronisation. What is the sequence of operation at the point of synchronising?
And before anyone says it I've looked on Google but not found anything that clearly outlines the sequence.
India - Member - New Member
Good Answers: 164
Re: Auto-synchronous motors
11/02/2010 2:11 AM
The major risk seems to be that the rotor may develop phantom poles which are phase-shifted wrt the rotating field, and when the DC is applied, the rotor may abruptly slip one pole, causing mechanical damage. There are specific methods to obviate this.
You might be interested in: AC Motors, Linear Motors, Auto Dialers
