Previous in Forum: Machining Time   Next in Forum: Air Handling Unit
HP Auto Steam Isolation Valves
11/03/2010 6:07 AM
I have a client who is having problems with 100 to,200 nb valves on a 40 bar system, can you recommend suitable make and type of valves? Another client has had issues with the following makes: Vanessa Triple off-set Unicon Triple off-set Velan Triple off-set Poymanball valve Copeland Ball valve Thank you and look forward to your suggestions.
Re: HP Auto Steam Isolation Valves
11/03/2010 11:53 AM
What is the temperature?
11/03/2010 2:33 PM
40 bar = 250 deg C approx.
Good Answers: 19
11/04/2010 12:07 AM
What do you mean by 100 to 200 nb? 100 mm to 200 mm/4" to 8"?
Globe valves? Try Klinger/Forbes marshall Piston-type Valves.
Register to Reply 3 comments
ducon (1); PWSlack (1); SloopJohnB (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
