Does anyone know the formula for calculating the force generated during a
discharge condition of high voltage surge arrester ? (force applied on
the ground connection lead)
Re: Mechanical Force in High Voltage Surge Arrester
11/03/2010 11:44 PM
There is minimal to no mechanical force imposed on the ground lead. The discharge current is an impulse; defined in the laboratory and in surge arrester standards as an 8-10/10-20 microsecond impulse current. It's essentially the result of a 1.2/50 impulse voltage applied between the arrester line and ground terminals.
It's not the same as a power frequency fault current which can result in significant mechanical force.
