Previous in Forum: Volvo Penta D5AT   Next in Forum: Insulating Base for High Voltage Surge Arrester
11 comments
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Working Principle of Transformer Winding Temperature Indicator
11/04/2010 10:26 AM
What is the working principle of a trnsformer winding temperature indicator?
If you can't find a way, make one........
Re: Working Principle of Transformer winding Temperature Indicator
11/04/2010 10:50 AM
You asking so many questions!
11/04/2010 11:19 AM
It depends on whether the device is a thermometer, thermocouple, thermistor, RTD, ICTD, color-change strip, or other; most of which can be searched.
[RTD = resistance temperature detector; ICTD = integrated circuit...]
India - Member - New Member
Good Answers: 164
11/04/2010 11:26 AM
Well put...GA
11/08/2010 10:59 PM
We can use any sensor that can measure temperature. Actually I meant that, I think we can not use the sensor directly to the winding because of high voltage problem. So we are using some indirect method for measuring winding temperature.
I asked about that......
Re: Working Principle of Transformer Winding Temperature Indicator
11/05/2010 4:01 AM
It takes the temperature of the winding using some form of sensor, and converts it to a signal that can be displayed on some sort of indicating device.
All thermometers do that.
03/18/2012 11:57 PM
My question is how we can measure the temperature of the winding directly since there is high voltage problem exist. Insertion of a sensor to the winding and the associated system including the outside indicator will reduce the insulation between winding and outside body considerably. So I think we can't use the sensor directly.
That is my point of question. How the measurement of winding temperature is done ?
Is there any indirect measuring method ? What is the method ?
I hope now Tornado, Kvsridhar & PWslack could understand my point...
03/19/2012 1:43 AM
I think that only the transformer manufacture could have this information. The windings themselves will of course be hotter than the surrounding oil, by an amount proportional to the load on the transformer (with some adjustments for ambient temperature, etc.)
03/19/2012 2:34 AM
Good Answers: 164
03/19/2012 3:39 AM
Glad you got something, though the pages don't load in my PC. Anyway, i thought i mentioned opto-isolation in the PM we exchanged?
03/19/2012 3:54 AM
Right.. As you told one way is to isolate high voltage area optically.
03/18/2012 7:26 PM
The winding temp. is always going to be higher than the oil temp.Also the winding temp. is going to be proportional to the load, so by using these two values you can get winding temp.
Register to Reply 11 comments
Anonymous Poster (1); eltech (1); justinanto1987 (4); kvsridhar (2); PWSlack (1); Tornado (2)
