Previous in Forum: Lead Acid Battery Charging   Next in Forum: IC's containing multiple AND and OR ciruicts
Electrical - Cage Motor
11/05/2010 7:44 AM
One phase of a 90hp,550V,3ph,1470rpm,sq cage motor is showing '0' IR value b2in Ph-Earth.Why only one ph got burnt?
Re: eletical
11/05/2010 8:02 AM
hi,
maybe because the voltage on that phase was not same as the other 2 phases by some reason, and that phase winding was pulling higher amps!
must be there is circuit brekaer for this motor, is it the right size to protect your motor?
Re: Electrical - Cage Motor
11/08/2010 9:36 AM
It might be that in connecting itself phase to earth to produce the fault it has become diconnected from the other two phase connections internally.
The motor needs rewinding or replacing.
Register to Reply 2 comments
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
