Previous in Forum: Motor Starter   Next in Forum: Lake of Phase Voltage (One Phase is Missing) for 3 Phase Motor
India - Member - New Member
Controller problem! (Urgent)
11/06/2010 3:49 AM
Hi all,
My working area is Stacker Cum Reclaimer{SCR (L&T)}. I am facing a strange problem. we are using two ABB 800 vvvf drives here. one for Slew (for doing left-right BOOM conveyor) and other is for LT(for Long Travel SCR). we are communicating all drives and Encoder by profibus cable.
Now problem is that when we travel SCR, an error is comes in profibus cable adapter and Incoming ACB get tripped. Sometime primary controller is switches on to secondary controller. Strange thing is that sometime problem occurs 20-30 times in one hour and sometime it dont come for 24-36 hours.
what we did till now is that we disconnected ACB trip command and give permanent 110V to respective relay(auxiliary contactor). but after that our control supply getting tripped so we provide seprate control supply. After that boom conveyor motor is tripping. We disconnect motor encoders as they only use in auto mode which not used here and changed the whole profibus cable. At every step we got relief for 24-36 hours.
Any suggestions or ideas are welcomed….
pstanwar9229
Pathfinder Tags: AC800F reclaimer stacker
Re: Controller problem!!!!!!(urgent)
11/06/2010 5:51 AM
Yo Pstan
you're located in India so one of my guesses with what you describe is
Humidity.
Dry out the profibus adapter with a hairdryer.
Had something similar in South America during monsoon times.
T L.
Humans use 10% of their mind , WE take the rest
11/06/2010 6:56 AM
Hi timelord,
Thanx for ur advise. want to tell u that all profibus adapters are in side E-house or MCC room under Air conditioned atmosphere.
And yes i am from India but this is not a monsoon season here. But u could be right on humidity prospective cos my workstation is just 200 Km away from sea so humidity level is usually high. But i dont think that it is due to humidity but still i'll try to do what u said.
pstanwar9229
11/06/2010 7:01 AM
Check also the back of the adapter
there might be some railcreep between the connectors
T L.
Re: Controller problem! (Urgent)
11/08/2010 6:00 AM
Disconnect everything . No tripping then.......
11/08/2010 9:04 AM
wow... what an answer... wt a mind u hv!!!!!!
pstanwar9229
Anonymous Poster (1); pstanwar9229 (2); timelord (2)
