Previous in Forum: How Reduce the Pump Capacity   Next in Forum: Wagon Tippler
Upgrading Pump Capacity
11/06/2010 10:40 AM
Hi All
I am in the process of upgrading an old pump with new pump that has higher flow/head output. what parameters should i check to make sure the new pump will be working fine with regard to
suction pressure, flange to flange dimension, discharge pipe pressure rating, discharge pipe size,...etc
please give your comments with regard to these parameters and any other concerns.
Thanks
Re: Upgrading Pump Capacity
11/07/2010 7:50 PM
The things you mention will all be in the picture. A critical item not yet mentioned is the NPSHa of the system vs NPSHr of the new pump at the the new flow rate.
What type, flow, hp or kw, and connection sizes are both pumps?
11/08/2010 9:47 AM
appreciate your comments
both pumps will be same type which is vertical multi stage centrifugal pump. The new proposed pump will be rated at higher flow/head (17 m3/h, 152 m).
with respect to NPSHr the charactistic curve of the pump is not having this curve. i am ignooring this because the pump will be running under positive suction head. hope my assumption is correct.
Any feed back from you regarding calculation of NPSHa and NPSHr will be appreciated.
11/08/2010 10:34 AM
  • A primary parameter is the ability of the piping to withstand the higher discharge pressure without rupture.
  • What about relief valve sizing for the higher flow?
  • Any bursting discs downstream?
  • Higher flow and pressure requires higher power, which is the product of the two:
    • Is the electrical supply sufficient?
    • Is the motor cable correctly sized?
    • What about motor overload protection and circuit protection co-ordination for both this and other circuits conencted to the distribution point?
Register to Reply 3 comments
Anonymous Poster (1); PWSlack (1); Tornado (1)
