Previous in Forum: Sea Bob Batteries Needed   Next in Forum: LT Breaker Tripping
Inductive Coil
11/08/2010 6:49 AM
I want to know as follow....
AC can not pass through Inductive Coil then How come AC is passed through Transformer and AC coils used in relays ?
Regards
Kiran
Good Answers: 143
Re: Inductive coil
11/08/2010 7:07 AM
Of course ac can pass through an inductive coil. There is impedance to its "flow", but that's not the same as "no flow". Even an ordinary piece of wire has inductance; yet ac current flows.
Good Answers: 918
Re: Inductive coil
11/08/2010 7:16 AM
Yes, it does, but It all has to do with the inductor's value, load resistance, and the frequency of the AC signal. There are other factors, too. However, the amount of AC signal passed depends on those factors, in general.
Here is a link on INDUCTANCE that explains the details.
Good Answers: 266
Re: Inductive coil
11/08/2010 7:24 AM
It's about how it is wound and the core material. You should study inductance if you really want to know the answer to your question.
http://en.wikipedia.org/wiki/Inductance
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/induct.html
http://electronics.howstuffworks.com/inductor.htm
Re: Inductive Coil
11/08/2010 9:14 PM
Dear Kiran, It may also surprise you to know that heater manufacturers, wrap coils of wire …. calibrated to a certain resistance and rate them at a particular voltage, in order to achieve a specified wattage per unit area. Warmest Regards, Ray
klearzen
Register to Reply 4 comments
Anonymous Hero (1); klearzen (1); ozzb (1); TVP45 (1)
