Previous in Forum: Testing Service - To Know What Type of Material   Next in Forum: Plastics Coating
High Speed Pumps
11/08/2010 8:38 AM
Does anyone know of any pumps that can fill a volume of 3.44 cc of a liquid that has the viscosity of about 4000-9000 cPs at a fast rate of 150-300/ minute?
Thank you,
Tom
Re: High Speed Pumps
11/08/2010 9:56 AM
It's the sort of application that needs a fast-acting solenoid valve, not a pump.
11/08/2010 10:51 AM
I'm not sure of terminology, but I envision a single-stroke piston pump sixed at 3.44 cc, operating off a constantly pressurized manifold that refills the piston on each upstroke. Maybe search on something like "liquid dispensing (or metering) pump"?
11/08/2010 1:38 PM
Maybe "plunger pump"?
Good Answers: 48
11/08/2010 3:23 PM
Check out FMI (Fluid Metering Inc) in NY state (I have no connection with them). They make a ceramic piston metering pump, with adjustable stroke. I'm not sure if they get up to 300/min. If not, you might have to look at metering/dispensing systems, rather than pumps. Nordson Corporation do a lot of stuff for metering/dispensing adhesives.
11/08/2010 3:27 PM
Excellent Thank You!!
11/08/2010 3:32 PM
A metering pump rated for high viscosity will work.
I can size one for you. I have the ability to go to 20,000 CPS, 150 PSI, and
flows to 37.9 LPH.
Good Answers: 141
11/08/2010 6:52 PM
Is it to fill a series of little bottles? In this case, you'll need 2 ore more dosing pumps.
They come with adjustable stroke and a turntable to feed the bottles. (like the 1 dose shampoo and soap, used in hotels).
Plenty of room here
Register to Reply 7 comments
Anonymous Poster (1); dvmdsc (1); Holzfeller (1); PWSlack (1); sebie (1); simektp (1); Tornado (1)
