Previous in Forum: DP Level Transmitter Showing Error of About 20%   Next in Forum: Closed Boiler Drum Level Calibration
Recommended Practice - Tank Farm
11/09/2010 2:01 AM
Hi,
Theres a tank farm , with all tanks seperated by a dike -with a common road running from North to South. There are some level instruments and Air Operated Valves For each tank
May I know what is the industry practice for installing Junction Box
Q1) For each tank One Number of Junction box located inside Dike
or can we select
Q2) One Number of Junction Box for Two tanks adjacent to each other, located in the main road
Regards
Jose
Re: Recommended Practice - Tank Farm
11/10/2010 3:33 AM
2 is to be preferred on the basis that it uses half the number of junction boxes than 1.
11/10/2010 3:57 AM
Normal Industrial practise is to take the instrument cables to respective instruments after the dyke wall in cable trays. If your dyke wall in not concreted you can use UPVC conduits or GI conduits, you can select a common location for the location of the junction box, so that you can use cable trench to take cables after the dyke wall to junction box.
Are you going to use LC cables, Does all instruments are connected to common control? Answer this, so that i can explain you further with alternate solutions too.
Register to Reply 2 comments
