Previous in Forum: Install Pad Eye On The Existing Structure - Inside Generator Room   Next in Forum: Tuning Ceramic Resonator Rods By Grinding
Hard Spring Steel Wire Joint Welding
11/09/2010 9:21 AM
what type of welding will be suitable to join two ends of spring steel wire , since its already a hard wire after getting red hot in butt welding , or spot welding , it gets more brittle and breaks , from the joint
any suggestion .....
shamsher singh (mech engineer manufacturers)
Re: hard spring steel wire joint welding
11/09/2010 9:55 AM
Usually Spring steels are high carbin steel and hence are difficult to weld.
replace the spring instead of trying to repair.
UD15
11/09/2010 11:56 AM
its not a repair of spring , we are planning for high production of spring steel wire ring used for automobile component , we need to weld 50,000 pieces per day .
11/09/2010 1:08 PM
Are you tempering after welding? The heat from welding is no doubt hardening.
11/10/2010 1:30 AM
no we are not tempering it , instead we tried it dipping into lime powder instantly after welding joint when red hot
11/10/2010 8:53 AM
Have you tried tempering after welding? Do you have an oven?
If I recall correctly, the metal incorporated into the weld puddle will require a very long soak time... and then will still not be a pliant/flexible as subject metal.
Your quench in powder, is that helping at all?
11/11/2010 3:34 AM
I'm not a metallurgist, but I believe you will need to temper the heat affected zone. If the base material was not already spring-tempered, you might get away with your current process.
The alternative is to weld the pieces BEFORE hardening & spring-tempering.
Register to Reply 6 comments
Anonymous Poster (1); Doorman (2); metal master engg (2); pantaz (1)
