Previous in Forum: Hard Spring Steel Wire Joint Welding   Next in Forum: Hot Water Pipe Sizing
Tuning Ceramic Resonator Rods By Grinding
11/09/2010 10:59 AM
Is there a better grinding wheel than diamond which I can use to grind ceramic resonator rods? Currently, I'm using 100 grit diamond wheel mounted on a toolpost grinder on a hardinge toolroom lathe. The result is not satisfactory. I cannot prevent chipped edges. The requirement is maximum of 4 chip outs no more than .005" wide.
Thanks,
Chito
Pathfinder Tags: CERAMIC GRINDING
