Previous in Forum: Tuning Ceramic Resonator Rods By Grinding   Next in Forum: Pressure Gauge Sticking
Hot Water Pipe Sizing
11/09/2010 11:16 AM
Hi guys,will you clarify me on the following for office building hot water pipe sizing. For same Fixture Unit Value, ASHRAE Modified Hunters Curve and Internation Plumbing Code,APPENDIX-E (Table E103.3(3) give different flow rates causing different pipe sizes. For example, for a fixture unit value of 140,ASHRAE Modified Hunters Curve indicates flow rate of 20 gpm (for Office Building) while International Plumbing Code,APPENDIX-E (Table E103.3(3) indicates flow rate of 52.5 gpm. Which flow rate (gpm) to use for hot water pipe sizing?
Re: Hot Water Pipe Sizing
11/10/2010 3:37 AM
The larger one.
11/10/2010 12:48 PM
Thanks. I wonder sometimes why gpm values differ so much.
Register to Reply 2 comments
