Previous in Forum: Proposed Primary Appliance The Master Home Clock   Next in Forum: Missile Launch Off California Coast
12 comments
Instron Testing Machine Programming
11/10/2010 2:49 PM
At our company we do tensile and flexure tests on different plastics using a single column Instron machine on a regular basis. I am currently working on a new project and would like to know how much force has to be applied on a wire 2,5 x 110 mm in diameter in order to push it trough a 2,7 x 100 mm tube filled with a slightly abrasive substance with a consistency similar to toothpaste . I would like to establish a norm for "substance A" (which will be the predicate), in order to compare it with other substances having a different composition. Any ideas?
Re: Instron Testing Machine Programming
11/10/2010 3:26 PM
How do you propose to push a 110mm "wire" through a 100mm hole?
What's the wall thickness of the 100mm "tube"? What material? Etc. Etc.
Please give more detail.
11/10/2010 6:16 PM
Think the OP got length & diameter mixed up, mate. Just bad wording.
11/10/2010 6:28 PM
Which still leaves a 2mm interference in the middle case. And we haven't even begun to talk toothpaste.
I'm confused by the fact that he does "tensile and flexure tests on different plastics"
but now he's pushing "wire" into a hole?
Help me I lost.
11/11/2010 1:31 PM
OPPPS, you are right! Measures are as follows: wire diameter: 2.5mm, lenght: 110 mm. Tube diameter 2.7.. x 100 mm lenght
11/11/2010 1:35 PM
Thanks,
Snaketails already explained it to me. Boy, I'm dense!
11/10/2010 4:12 PM
If you want to do it real fast, keep F = ma in mind.
What does the Intron measure, anyway?
11/11/2010 1:34 PM
Established in 1946, Instron manufactures and services materials testing instruments, systems, and accessories, providing you with comprehensive solutions for all your research, quality, and service-life testing requirements. Our machines evaluate the mechanical properties of materials and components using tension, compression, flexure, fatigue, impact, torsion and hardness tests. We offer a broad range of service capabilities, including calibration, training, technical support, and assistance with laboratory management.
Good Answers: 15
11/11/2010 1:56 AM
I don't have an answer for you, but from what I'm reading, and others seem to have a problem seeing it this way..
pushing a 2,5mm dia rod by 110mm long down a tube with ID of 2,7mm and length of 100mm
Mate, I think the best way to do it is to do physical measurements, as the material your using, will have different abrasion characteristics depending on what the abrasive is..
Also, if it has the consistency of toothpaste, is the abrasive material also pumped in so the rod is not pushing it out on its first application
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
11/11/2010 2:13 PM
"I don't have an answer for you, but from what I'm reading, and others seem to have a problem seeing it this way.. pushing a 2,5mm dia rod by 110mm long down a tube with ID of 2,7mm and length of 100mm" You are right, wrote in a hurry and mixed up the figures. I would like to avoid physical measurements as we are dealing with a practical problem: the user of a device pushes the material contained within a tube (cannula / needle) by means of a stylet (rod / wire). There is an ideal consistency for this material at which the stylet glides trough the cannula. I would like to know how much force is applied on the stylet to empty the tube. http://picasaweb.google.com/lh/photo/R21zR59I7qd8zbwjDYwXFKE3fySz0PP7F1rd0Zugn1g?feat=directlink In this pic you see a tube 40 mm in dia x 150 mm in length that is fixed to the plate of the machine. The upper end is closed by means of a metal disc acting as a lid, which has a 3mm hole in the center. The cannula (tube) is passed trough this hole. As the cannula has got handles that fit into a groove, it remains in a fixed position. Once cannula has been filled up, the trocar is inserted 10 mm into the cannula and the measuring tool of the Instron´s "arm" is moved downwards until it rests on the top of the trocar. When the operator hits "go", the arm starts descending at a speed that has been previously programmed. http://picasaweb.google.com/lh/photo/Fs9wpuVLNya8hxS42dVVqKE3fySz0PP7F1rd0Zugn1g?feat=directlink To those with experience in the use of Instron´s: what would the best parameter variables for doing this test? Thanks a lot!
11/11/2010 6:49 PM
Here are your pics, to save others the trouble:
I'm having a bit of difficulty sorting things out, here. Your post #7 suggests that you are an Instron employee, yet you are asking "those with experience in the use of Instron´s" for help. Shouldn't Instron (the company and its staff) be in the best position to answer this? Perhaps your question should have been addressed to "those with experience in the use of these or similar testing machines". Please elaborate.
11/12/2010 9:18 AM
Thanks JohnDG! I tried to upload these pictures a lot of times, but something went wrong on and on. Great you could solve this problem. In regard to your question: I do not work for Instron. Tornado asked post # 2 what a Instron is, so I pasted info from this company´s website to the reply.
11/12/2010 11:44 AM
Fair enough - it was the "We offer a broad range ..." that confused me. Often a good idea to make it clear when you're quoting something or someone.
Register to Reply 12 comments
JohnDG (3); lyn (3); r&ddoc (4); Snaketails (1); Tornado (1)
