Previous in Forum: Maximum Vibration - ISO 10816 Class III Zone B   Next in Forum: Water Flow PSI
Actuator Type?
11/11/2010 5:19 PM
I have an application where I need to design a system that will support an air nozzle above a horizontal plate. The nozzle will need to move back and forth over the plate - 29" travel in one direction. Speed of approx. 40 feet per minute. Speed must be consistent from one end of the stroke to the other end. Nozzle has to stay perpendicular to the plate. The actutor will need to be at one end with the nozzle travel all overhung from the actuator at the edge of the plate. It will need to operate basically 24/5.
There are lots of ways to do this. Interested if anyone has had any particluar success with one type of actuator versus another.
Re: Actuator Type?
11/11/2010 5:58 PM
One suggestion: a ball screw with reversible gearmotor drive.
Good Answers: 123
Re: Actuator Type?
11/11/2010 10:11 PM
A hydraulic cylinder with 29" of stroke, and automatic reversing.
Bob
Re: Actuator Type?
11/13/2010 11:59 AM
only in one direction?
try air operated cylinder with flow control valve
usually this is a two direction operation
or maybe your sheet is moving on a conveyer
Good Answers: 21
Re: Actuator Type?
11/13/2010 1:08 PM
I've had great results using Tolo-matic products. The rodless band air cylinders are reasonably priced and you just almost can't kill them, as long as you don't have mechanics going around squirting WD-40 in the air ports. They're also fast and very repetitive. If you're just looking to run an air knife to clear debris, etc. this works great. If you are looking for a high degree of accurate timing / position then a ball screw type of unit is best but cost is greater.
http://www.tolomatic.com/products/product_detail.cfm?tree_id=101
I use alot of the BC2 series on this page:
http://www.tolomatic.com/products/item_detail.cfm?TREE_ID=108
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
Re: Actuator Type?
11/15/2010 2:58 AM
You can use pneumatic cylinder for this application since they are maintanance free. Since your load requirement is very small, choose an actuator with sufficient stroke, small bore size, small outer dimensions, with flow control valve (for consistent speed), and rod eye mounting. I prefer METALWORK cylinder which gives smooth operation.
And, Air knife seems to be set to your application which eliminates cylinder and nozzle. Refer http://www.exair.com/en-US/Primary%20Navigation/Products/Air%20Knives/Pages/Air%20Knives%20Home.aspx
Regards,
RAMARAJ
jsramraj@gmail.com
Re: Actuator Type?
11/15/2010 3:16 AM
Hi, I've done this only vertically and the best way we found was to have a carriage to mount what ever you want to use it for,driven by chain with a ball bearing on the chain which locates in a channel on the carriage,the chain is driven by a geared motor with a sprocket & supported at the other end by another sprocket,you can have the the chain drive vertically & the carriage horizontal by mounting the drive channel vertically (better for the chain).
Bazzer
Register to Reply 6 comments
Anonymous Poster (1); Bazzer Englander (1); bob c (1); jsramraj (1); Switchman (1); Tornado (1)
