Previous in Forum: Inverted Blower Fan   Next in Forum: NGT & NGR Application.
Driving Earth Rod
11/12/2010 10:56 PM
Hi, All
Driving ground rod into the soil at the forst place cannot get the low resistance, what will be the cause is it the water table hasn't reach. or the rod not yet merge to the soil becuase it newly installed.
Any compound to poured during the gound installation.
regard's
Newbie
Re: driving earth rod
11/13/2010 12:45 AM
Once I had to add a salt and water to the soil around a ground to improve the ground for RF reception. I must stress though that this was a temporary installation. Grounding quality varies wildly with your geology and soil conditions. (Is that redundant?) How critical your ground quality will also depend on the purpose for your ground; power station ground, lightning protection, building ground, RF or other sensitive electronic work, etc.
Consult with your local building code and/or building inspector for what is acceptable for your location. You may just have to add a halo ring and more rods.
11/13/2010 4:45 AM
Salt water.
Google "ground rod installation"
Netherlands - Member - New Member Canada - Member - New Member
Re: Driving Earth Rod
11/13/2010 10:06 AM
As mentioned, grounding varies wildly with the local conditions. Are you in clay, sand, bedrock etc.
I have had occasion where we had to drive about 6 rods interconnected adn about 3 meters apart to a depth of 6 meters to achieve the proper grouding.
See if there is a local Lightning Protection and Grounding installation company in your area. They will be able to guide you on this matter.
Also, how are you measuring the ground resistance?
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use. Galileo Galilei
Good Answers: 58
11/14/2010 7:02 AM
In conjunction with lynlynch's advice, also try a Google search of "chemical ground rod".
You may find something there that will help.
Good luck - KJK
11/15/2010 9:57 AM
In the absence of salt water to improve the earth connection, large quantities of animal urine can sometimes prove an acceptable substitute.
11/15/2010 10:17 AM
I see a keg party in the near future.
jk (1); KJK/USA (1); lyn (1); PWSlack (1); redfred (2)
