Previous in Forum: Convert 1 Phase AC Source to 3 Phase   Next in Forum: Formulas - Lamp Spacing
Quiz on Mosfet
11/14/2010 7:45 AM
Sir,
I did not know how to solve a mosfet problem specified below, please help me with detailed solution as soon as possible
Problem :
Find the power dissipated in Ron, if the Mosfets are accurately represented by the switch resistor model, where the threshold voltage Vt = 2V and the on-resistance Ron = 100 ohm.
Re: Quiz on Mosfet
11/14/2010 7:49 AM
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider this and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other college assignments is to help you learn - by practice, repetition, and self-discovery. (thanks STL Engineer)
Re: Quiz on Mosfet
11/14/2010 8:03 AM
The answer is 42.
I leave it to the student to explain why.
Good Answers: 58
Re: Quiz on Mosfet
11/14/2010 8:49 AM
Hint - (In you text book on page 156)
Re: Quiz on Mosfet
11/14/2010 9:54 AM
The answer is 52,
Re: Quiz on Mosfet
11/14/2010 2:32 PM
Depends on how may beers Ron has had. Usually after the 5th one, Ron feels thoroughly dissipated.
Anonymous Poster (1); KJK/USA (1); lyn (1); redfred (1); Usbport (1)
