Previous in Forum: Steam Flow Measurement by Using Ultrasonic   Next in Forum: Job Search
12 comments
Fiber Optic Cable in HDPE Pipe - Need Help
11/15/2010 8:49 AM
Dear all,
I've got one project of laying Fiber optic cable 4 core (armored) in HDPE pipe of 110 mm dia. I need to lay/pull at least 7 fiber optic cables in one HDPE pipe/duct of 110 mm. total 65 kms of cable to be pulled. HDPE pipe will be in excavated trench. Length of one HDPE pipe is 50 meter. Also at every 200 meter there is either cable chamber/pit or road crossing consist of GI pipe of 110 mm. I need to pull this very very soft cable with out damaging it. Kindly direct me to proper method for the same.
Thanks & Regards,
Fibro Optico
Re: Fiber Optic Cable in HDPE Pipe - Need Help
11/15/2010 10:29 AM
Instead of 110mm GI pipe being coupled to the HDPE pipe, consider using larger GI pipe at the road crossings as a sleeve, with the HDPE pipe running continuously through it.
11/15/2010 1:31 PM
Armored fiber optics is not as delicate as it seems to be. as long as you wont exceed the bending angle more than lets say 60 degrees than you should be fine. if the fiber you have is already terminated than you should watch for the connectors so they wont get damaged but even if they will you can have a technician to re-terminate them. so using regular drag-line or snake should be a good solution.
i am telecommunication technician for past 3 years and we usually pull fiber optics in very rough conditions and it was always fine.
11/16/2010 6:07 AM
i am planning to pull the FO cable through nylon rope. what are the chances of FO cable being damaged??? what should i take care while i am pulling the cable.
Thx all for reply.
11/16/2010 11:50 AM
For electrical wiring there is "pulling soap" to lubricate the wires. I don't know if FO cable would have a problem with this goop on it.
Good Answers: 58
11/16/2010 1:53 PM
Yes, you do have to be careful.
Your FO cable supplier can provide you with the written cable spec for your particular cable which will show the maximum pulling force and pulling radius.
If you have the cable manufacturer name and the cable part number, try to enter that in Google followed by the word "Specification".
Example: "Belden M9B039 003X Specification"
You can also Google "how to pull FO Cable in conduit" for more info.
Research before you pull and you will save yourself time and money.
11/16/2010 2:09 PM
If pulling a bundle of cables, you can use one or more "cable pulling grips". They are made for pulling at the end or for intermediate additional grips along the cable bundle. You could throw in a few spares in case of individual cable breakage.
11/16/2010 2:22 PM
being honest with you i don't have much of a theoretical knowledge but i have pretty good field experience.
in practice this job is much easier to be done than in theory. if the pipes are straight than there is no worries that you will have problems with completing the task. just use vacuum to pull the drag-line through and re-pull the fiber.there is no way the fiber will get damaged in these conditions. it could get damaged if bent too much or the wire is "pinched" which will cause damage of the protection and loss of the light. if you could add more specifications of the cable and how its armored than we would be clear if there is a risk of a damage.
if the pipes have multiple curves than on the distance of 200 meter you could get stuck and you should reconsider adding more pull-boxes.
please add more specifications from the manufacturer.
11/18/2010 3:19 AM
Thanks every one for the reply. At present the only data i am having is cable type. it says 04F MLMW SM 9/125u UT ARMD ORANGE LSZH OFC. Cable company Finolex.
11/18/2010 7:44 AM
and here are the specs
4 Core Cable , High Density Polyethylene , ECCS Tape Armour , Flame Retardant Low Smoke Zero Halogen , Control , Fiber Optic , Orange
FINOLEX CABLES LIMITED
11/24/2010 6:01 AM
01/06/2011 3:36 AM
we are an Indian manufacturer of HDPE PIPES and can supply the 110mm dia HDPE PIPES with rope inserted and also with silicone core .
Also we can supply pipes from 25mm to 200 dia in different wall thickness.
pl contact :
MAGNUM FIBRES PVT.LTD
132A,MANCHESWAR INDUSTRIAL ESTATE,
BHUBANESWAR-751010
INDIA
MAIL :malla@magnum-india.com
www.magnum-india.com
01/28/2011 2:41 AM
dear sir,
I am a CR-4 member & we manufacture HDPE PIPES of sizes 20,25,32,40,50,63,75,90,110,125,140,160,180 & 200 mm dia in different pressure classes,and also in grades of PE-63,PE-80 & PE-100 under IS 4984:1995
Besides we also have silicone coating arrangement in core of pipes also with arrangements of rope insertion.
we also manufacture telecom ducts in sizes of 32/26,40/33 and 50/42 etc with silicone core & rope insertion arrangements.
we can manufacture HDPE Pipes in customised lengths, colours,thickness as per your requirements & have capacity to execute bulk business with fast delivery schdule.
pl let me know if we can associate for better business.
Thanks,
a.p.malla
director
magnum fibres pvt.ltd
,132a,mancheswar industrial estate,bhubaneswar-751010,orissa
www.magnum-india.ciom
CR4 Admin - phone number and email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You may share this information via the private messaging system if you wish
Anonymous Poster (4); apmalla (2); KJK/USA (1); shadowman (2); Tornado (3)
