Previous in Forum: Reducing Gasoline Use   Next in Forum: BMW Braking Issue
8 comments
Truck Seems to Lose Power Going Up Hill
11/17/2010 12:07 PM
I have a 1500 1995 chevy and it has alot of miles on it. When i am going up hill it seems to loose power. HAve any suggestion?
Re: truck seems to loose power going up hill
11/17/2010 12:15 PM
One suggestion would be to provide more info, like how many miles, how steep of a hill and what troubleshooting you have done yourself so far.
Re: Truck Seems to Lose Power Going Up Hill
11/17/2010 1:41 PM
Well, the truck is 15 years old, and is a high miler...
Perhaps the LynDoor™ Industries 'Bowtie Generator' is for you. Replace the tired old Chevy Bowtie grille emblem with the sleek propellor-like generator bladeset provided in the kit, and increased power1 for your truck is available with a flip of a switch.
This increase2 is accomplished through a traction motor replacing the existing pillowblock for the rear driveline. The entire rig only adds 915 pounds to the vehicle weight, and can be installed by anyone with about $4,000 worth of mechanic tools and a lift in only 32 hours.
1) Above 3100 RPM; under 3100 RPM, there is a slight parasitic effect.
2) Power increase reported to be as high as 1.3%. Your results may vary.
11/17/2010 11:12 PM
no no your thinking this thing way to much. spend 600.00 and put a 250 shot of nitrous on it. then HTFO.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
Good Answers: 97
11/18/2010 2:08 AM
1995 gas
11/18/2010 6:21 AM
You could make only left turns and go stricktly downhill.
h
11/18/2010 12:28 PM
One thing it could be is a clogged fuel filter.
11/18/2010 1:38 PM
It's 15 years old with lots of miles on it. Your compression is probably way down from it's prime. This is more apparent when going up hill. Loss of compression = loss of power. Suggestions:
Rebuild engine
Buy new truck
Buy new engine
Learn to live with it
Using a heavier weight oil might give it a little more power and prolong the inevitable for a little while.
11/18/2010 2:02 PM
Have you checked the compression? Could be low compression. Possibly worn camshaft as it needs more air under load. Air filter, fuel filter, wouldn't hurt checking plugs or wires. Other than that, if you aren't getting a code, that should be it.
Anonymous Poster (1); bwire (1); darren2264 (1); Doorman (1); jstork (1); kramarat (1); Tornado (1); Usbport (1)
