Previous in Forum: HVAC Load for Residences   Next in Forum: Interpass Temperature
India - Member - Rajasekar
Pressure Vessel Design for Sub Zero Design Temperature
11/18/2010 8:06 AM
Pls help me,
As per ASME Sec-VIII Div 1, Any Specific class or requirement for design of pressure vessel which has a sub zero design temperature.
Re: Pressure Vessel Design for Sub Zero Design Temperature
11/18/2010 12:10 PM
There is a "decision tree" for this that is a bit complex. I may be out of date, but the basic idea is like this:
For ASME, low temperature for CS is below -20°F. If you are warmer than that, nothing special is required. In the range of -50°F to -20°F, you can check for the relation of "coincident temperature and pressure." If it can be ensured that as the temperature falls, the pressure also falls, and if you use a suitable low-temperature steel such as 516-70, impact testing may not be needed. The vessel stamping will reflect this with an extra line such as "MDMT -50°F at 60 psi" (MDMT = minimum design metal temperature). For CS below -50°F, impact testing is required.
That is just a brief outline, so you will need to check the Code carefully. Note also that if any other codes apply (such as Coast Guard), the cut-off point for low temperature may differ, and there may be further requirements.
Good Answers: 137
11/19/2010 6:46 AM
Good answer from me Tornado (not that you need any more )
Codey
Register to Reply 2 comments
