Previous in Forum: Homo-polar motor   Next in Forum: Load Calculation
Insulation Resistance Test
11/19/2010 12:36 AM
What will happen when testing an Insulation Resistance of a transformer while the oil is hot.
“The engineer has been, and is, a maker of history”-James Kip Finch
Re: Insulation resistance test
11/19/2010 2:01 AM
What do you expect i guess the insulation resistance will increase.kindly tell what is the method used for testing. Oil insulation property decreases with more usage(making and breaking-arc) due to the increase in carbon content.
Good Answers: 131
Re: Insulation Resistance Test
11/19/2010 4:03 PM
Insulation resistance will vary with temperature. There are correction factors that reference it to 25C.
Search Google for "Insulation resistance temperature correction" and you will get a lot of hits. Here's the first one I got, with a good nomograph:
http://www.uiitraining.com/b51a/200/eer365.htm
11/22/2010 10:43 AM
Exactly the same as when the oil is cold.
If the transformer cannot withstand the applied test voltage at both ambient and at normal operating temperatures, then it is faulty.
Register to Reply 3 comments
Anonymous Poster (1); PeterT (1); PWSlack (1)
