Previous in Forum: Failure of Single Conductor MV XLPE Cable at Joint   Next in Forum: Single Phase Transformer
Failure of Single Conductor 34.5kV XLPE Cable Due to Circulating Current
11/19/2010 7:21 PM
We have 34.5kV single conductor 630mm2 run for approx 1.5Km from SWGR to Xformer (12 cables 4 cirts of 3 cables to 4 Xformers.
WSe have Link Boxes at Source and Xfmr end with Surge Volt Limiters and the Shield and Armoured bonded together and individualy run to the link Boxes
We additionall y haved 3 joints on the run. @ joint are the conventional Raychem type with the Shield and Armour isolated form each other.
The mid point joint has the Armour and the Shield bonded together on both the load side of the joint and the source side of the joint with the load aside and the source side isolated from each other.
These are run to Link Box and connected in WYE to Earth
Although the connections are A B C on one set (load) and C B A on other set (source). We have current in the three connections on the load side and zero on the source side.
Two cables have failed at the armour spring ring at the last joint specifically at the side coming from mid point Link Box.
The other cables have been checked and we are experiencing very high temps at the spring ring at the other final joints
We have attempeted cross bonding at the mid point and have reduced the Circulating current in two phases to a minimum but still have a very high current in one phase.
I believe in isolating the armour bond to earth at the load end as I believe this is what is causing the circulating current to be high.
Any othe solutions????
Re: Failure of Single conductor 34.5kV XLPE cable due to circulating current
11/19/2010 7:59 PM
Good information for you here and here
12/03/2010 1:56 AM
Thank you for your information, although the information from Okonite Cables did not specifically address the problem, it provide information that led to other information and a discussion regarding the cable installation design and ultimately solving the problem
Re: Failure of Single Conductor 34.5kV XLPE Cable Due to Circulating Current
12/03/2010 1:52 AM
We found that the problem was due to the armor on the XLPE at the load end (transformer) was earthed through the cable gland, once this was isolated the circulating current which was carried through the shield and found the weakest connection at the joint causing heating up around the tension coil provided in the kit supplied and causing a failure. Subsequent rveiwing of the other joints of the 12 cables (4 separate circuits) show evidence of heating at the joint area. We now have to uncover and inspect the joints a total of 48.
Conclusion is that there are guidelines regarding induced voltages in long run cables and attention as to be paid to circulating currents. Both IEEE and IEC have code guidelines with various options to address these issues.
However design engineers need to be very specific as to what connections must be made and provide detailed drawings for these connections and not leave it up to the cable installation contractor.
Register to Reply 3 comments
