Greetings everyone:
Yesterday I installed photo and video software (Arcsoft) from CD that came with camera via DVD drive on Dell Inspiron 1525. Then reinserted the CD and attempted to install driver for a key chain photo display . . . bauble that charges off the USB. That time, when disc was inserted it did not auto start and also did not appear of drives listing when the Computer page was opened. Then, when repeating insertion of CD, I noticed optic drive indicator light to go on momentarily (perhaps several seconds), go off, and then . . . nothing. As for the photo frame bauble, plugging it not the USB port did cause it to light up, but no display or other evident functionality.
Later that night, in preparation for a subsequent new installation, I performed total defrag of the system and (virtual) back up volumes on the hard disc.
Today - it having slipped my mind that the apparent malfunction might be a "computer" as opposed to installation medium problem I inserted a Windows Office installation CD. Again, the CD failed to auto start and load, and could not be found by clicking on Computer.
Next I went to the Device Mgr to see if the DVD drive was, or could be enabled. Checking the drive's condition, rather than "working normally" a problem message appeared, to the effect: Windows cannot load the proper driver . . . which might be absent or corrupted. Do I want to check for solutions at Microsoft? I clicked yes but after waiting a while did not (and as I write this have not) received a reply.
Next I attempted to have the system search locally for drivers to reload; then searched online for updated drivers to download and install . . . all to no avail.
Finally, using the device troubleshooting facility in Vista Ultimate - condition: device used to work but not working now - I ultimately arrived at the instruction (obviously generic as will become evident) to re-install the driver using the Computer installation/repair CD.
But it occurred to me: How can that work if the corrective CD driver is on the CD which can't be read due to the suspect driver already on the computer hard disc?
Apologizing for over lengthy thoroughness, any suggestions for repairing the DVD drive are are gratefully appreciated. Or an interim solution that simply allows the Office installer to read by alternative means. (For example, could could an optical drive on an XPPro computer be used (to install on the Vista laptop) using a crossover network cable? I kinda doubt but . . . who knows for sure?)
Delluded anew
PS: Oh, I almost forgot. Here is the message that operating system generated to desribe the failure:
Description:
Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39.
Problem signature:
Problem Event Name: PnPDeviceProblemCode
Architecture: x86
Hardware Id: IDE\CdRomTSSTcorp_DVD+-RW_TS-L632H_______________D400____
Setup class GUID: {4d36e965-e325-11ce-bfc1-08002be10318}
PnP problem code: 00000027
Driver name: cdrom.sys
Driver version: 6.0.6002.18005
Driver date: 04-11-2009
OS Version: 6.0.6002.2.2.0.256.1
Locale ID: 1033
