Previous in Forum: GIS-SF6 230 KV Switchgear Bus-Bar Protection   Next in Forum: How to Convert Conventional Powered Motor/Pump with a Solar Powered One?
Electrical Power Cables Laying
11/22/2010 12:05 AM
Hi,
i am working in a combined cycle power plant,Its in commisioning phase.Here different sized cables of following specs i.e; 4 and 3 Core Stranded Cables Cu/XLPE/SWA/PVC-LSF: 600-1000V IEC-502,3 Core Stranded MV - Cables
Cu/XLPE/SWA/PVC-LSF: 6.35/11KV IEC-502,1 Core Stranded Cables Cu/XLPE/PVC-LSF: 600-1000V IEC-502 have been used for different equipments.Firstly these were laid in cable trenches.In rainy season cable trenches became full of water so to avoid water accumulation EPC contractor has filled the trenches with sand.Please
  • explain is it recommended/safe practice to fill the cable trenches with sand by any ieee/iec/ansi standard.also specify the standard
  • Please elaborate the effects (good/bad) on cable insulation,life and integrity with some supporting ieee/iec/ansi standard
Pathfinder Tags: cable
Re: Electrical Power Cables laying
11/22/2010 4:44 AM
we will think about it after commissioning. Now let complete the commsssioning ..............
11/22/2010 7:03 AM
Hi,
please advise,
1.) what is the length of the cable
2.) what is the services
3.) what is supply voltage
Regard's
11/29/2010 11:05 PM
Dear sorry for late reply,
length of the cable
Various lengths of cable used ranging from 10meter to 1000 meters
services
to supply switchgears from transformers,to supply motors from switchgears etc
supply voltage
6.6kV and 400V
Re: Electrical Power Cables Laying
11/22/2010 10:09 AM
Well, British Standard 7671 has a lot to say on cable sizing, loading and installation techniques...
11/29/2010 11:14 PM
Dear Sir,
Thanks for reply
  • Can it British Standard 7671 be provided by you or could you please refer some site to get it free?
  • It will be helpful for me if you could please comment against my concerns with arguments because it will take time to read the standard thoroughly
06/19/2023 6:17 AM
In an ideal world, standards need to be taken into account before work starts. That's called Engineering!
Standards take time and effort to produce and publish. The price is there to value that effort.
Register to Reply 6 comments
Anonymous Poster (2); PWSlack (2); shahzad (2)
