Previous in Forum: HVAC - Calculate CFM   Next in Forum: Sound From Bike Silencer
NPSH for Submersible Pump
11/23/2010 2:14 AM
Please can somebody explain me hot to calculate the NPSHa for submersible pump? Do I have to change sign of suction lift (.e. +ve)
Regards
Nandlal
Good Answers: 67
Re: NPSH for Submersible Pump
11/23/2010 3:10 AM
Dear Nandlal,
YES. But its a very simple question for which you can easily and instantly get answer elsewhere instead of waiting for response here. Please see www.pipeflow.co.uk/public/articles/
11/23/2010 3:21 AM
Thanks Pritam
But is there any difference between calculating NPSHa for centrifugal pump and submersible pump
Your reference dosent say specifically for Submersible pump
11/23/2010 6:41 AM
No need to do this for this one. It has its own level switch (the red thing).
11/23/2010 8:29 AM
From OPPAPERS.COM:
Calculating Npsh Of Pump NPSHA in the system is calculated as :
NPSHA = Terminal Pressure in the vessel (in guage)
(+) Static Head of fluid above pump centre line (see note).
(+) Atmospheric Pressure
(-) Vapour Pressure of liquid at pumping temperature
(-) Friction loss in suction piping up to pump centre line consisting of the following :
? Entrance and exit losses
? Loss in suction strainer
? Loss in control valves, instruments, exchangers etc. if any
? Line losses
Note : a) The height of liquid in the vessel should be taken to be at the vessel bottom tangent line.
b) Height of the pump centreline is calculated as follows :
HPC = HPB + F where
HPC = height of pump centreline above finished floor level
HPB = height of pump centreline above pump baseplate
F = height of pump foundation above finished floor level
HPB is estimated from the following table based on typical vendor information :Pump Flow Rate Height of Pump Centreline (m3/hr) above Base Plate HPB
11/23/2010 8:39 AM
Thank you all
Anonymous Poster (1); lyn (1); nandlal.aher (1); pritam (1); PWSlack (1)
You might be interested in: Submersible Pumps, Submersible Mixers
