I am working on an application that requires measuring around 100 ppm HF gas and I need to be sure that the HF gas will not condense in the pipeline or inside the measuring instrument. Therefore I need to know how to calculate the temperature at which a 100ppm HF gas will condense. First if the balance gas is a reasonably dry SF6 (less than -30 oC dew point) and also if the balance is dry N2.
