Previous in Forum: Next Steps   Next in Forum: Suitable Die Steel Material for Hot Forging Dies
Carbon Steel for Low Temp
11/24/2010 11:52 PM
I have chilled brine service with design temperature of -27deg C. As per standard, ASTM A 106 can be used upto -28C. But a few suppliers are insisting on using A333 (LTCS) material which would be about 25% costlier that A106. Which is the optimum choice out of these options:- a) ASTM A106 b) ASTM A106 with impact testing c) A333
Please guide..
Re: Carbon steel for low temp
11/25/2010 12:37 AM
If the standard says -28°C (-18.4°F), then 106-B should be acceptable regardless of what the supplier says.
As I recall, the ASME low-temp cutoff is at -20°F (~-28.9°C). However, US Coast Guard applications have (or had) a 0°F (~-17.8°C) cutoff. So it depends on what code has jurisdiction in the installation's location.
Good Answers: 243
11/25/2010 9:54 PM
Is the applicable code the real issue here? if -27 degrees is the operating temp and the spec limit is -28 degrees, That one degree of "temperature margin" seems to me to be A) not very much margin and B) less than probable temperature measurement error.
Milo
Milo (1); shahpolymers (1); Tornado (1)
