Previous in Forum: Carbon Steel for Low Temp   Next in Forum: Speaker manufacturing
Suitable Die Steel Material for Hot Forging Dies
11/25/2010 3:32 AM
kindly suggest me some suitable die steel material for hot forging dies as our die life is very less at present.
Re: Suitable Die Steel Material for Hot Forging Dies
11/25/2010 2:11 PM
I'd suggest asking your supplier of steel.
He will recommend something that is more expensive than your current steel costs, but will probably last longer. So, it's up to you to decide which steel is the most cost effective. Long runs may justify more expensive steel, while small runs may be OK with the current steel.
Maybe Milo will help you.
Good Answers: 243
11/25/2010 9:47 PM
You do not tell us your current steel grade, so how can we tell you what is "better?"
What is the failure mode of these dies that are failing?
What is the operating process/parameters that you are using?
What is the material that you are forging?
Milo
Expanded polystyrene (EPS)
11/26/2010 7:05 AM
CR4 Admin Deleted Post Reason: Spam
Styrene acrylonitrile is a copolymer
11/26/2010 7:06 AM
Let's talk about forming dies
11/26/2010 10:38 AM
shahpolymers, this is shameful. Spamming at it's worst.
You join a discussion forum, and LOAD it with advertising. Disgraceful. 11 posts at this writing, each one a link to your site.
I will petition CR4 Admin for your expulsion.
12/05/2010 8:12 AM
Try Typlex
Register to Reply 6 comments
Doorman (1); lyn (1); Milo (1); mtdmaker (1); shahpolymers (2)
You might be interested in: Forging Equipment, Forging Services, Wire Drawing Dies
